67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> brick sill below window on brick wall
How is the easiest way to create a window family with an angled brick sill. I created one with an extrusion but i dont know how to make the sloped opening in the brick part of the wall.
12 Posts No Rating |
Brian , i have been struggling with this area also. see attached rfa file that has an example of what you are after. hth geoffm Edited on: Fri, Jan 4, 2008 at 3:40:52 AM
Edited on: Fri, Jan 4, 2008 at 6:08:27 AM
That is what I'm trying to create. How do you make the opening?
i think i have it sorted. open window family for editing, turn on wall in view props. cut a section through the window. hilight cut opening(click on wall, tab till cut opening is displayed), click on edit and alter to suit required sill position ( eg 172 mm below frame) and save. u need to fill in behind with a solid extrusion to say the inner leaf thickness(for b/v) which allows space for your solid extruded sill bricks. i tried it on another window family which had a cut extrusion rather than a cut opening around the window frame. the cut extrusion was easier to edit . ( didnt need to fill in behind.) in both cases the section was handy. cheers geoffm
![2 Stars: 4 Votes](/images/stars_2.gif) |
I am trying to do the same thing. I have a brick wall (thin brick - "stick on" 1/2" thick actually) with a slopd brick sill under the window. When I use a wall sweep with the sill profile I created, it cuts the wall only where the face of the sill intersects the wall. I then have a piece of the wall reamianing from the top of the sill to the bottom of the window. I would think that there would be a way to increase the size of the cut above the sweep. I have tried to modify the opening and add an additonal opening. That works, but I have a huge hole under the window on the interior side of the wall. I tried to use a void as in the example above, but cannot get the proper angle set. (I want to still use a sweep for the sill seperate from the window). This is a basic construction method, you would think Revit shoiuld be abole to handle it. Any ideas?? Thanks.
----------------------------------- Revit Architecture 2010 |
Window in brick/stud wall |
Fri, May 26, 2006 at 2:43:48 AM
Sloped interior window sill in wall |
Tue, Feb 14, 2012 at 3:30:26 PM
Rowlock brick Sill |
Sat, Mar 17, 2012 at 8:01:34 AM
12
SLOPING CAST STONE WINDOW SILL APPLICATION |
Thu, Feb 28, 2013 at 8:38:42 AM
Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches |
Tue, Jul 24, 2012 at 5:31:29 AM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
