105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> HELP ME - export to .dwg problem
Thu, Jan 3, 2008 at 1:48:18 PM | HELP ME - export to .dwg problem
bimmonkey
Please help me if you can ... I've searched the forum, and don't see a question that addresses my issue.
I have gone into "Import/Export Settings", under the "Category" heading of "Walls" and created a new "Layer" (A-Wall-Finish) and applied that new "Layer" to Sub-Categories "Finish (4)" and "Finish (5)".  Along with the new "Layer" is a new "color ID", so that when it is exported to AutoCad, the "Finish (4)" and "Finish (5)" components will be a different layer than "A-Wall".
However, everytime I have done this, the entire wall assembly comes in as layer "A-Wall".
Anyone know what I am doing wrong?
I've searched the help section of Revit, but am afraid I am looking for the wrong thing.
Thu, Jan 3, 2008 at 2:14:03 PM | HELP ME - export to .dwg problem
NKramer
4 Stars: 9 Votes
Go to File: Export: Cad Formats
Click on Options
Click on Layer settings
Scroll down to walls and you should be able to pick or make up a new layer for the finishes to export to.
I'm sure that there is another way to change the export setting but I cant think of where it's located off the top of my head.
HTH
Nick
Thu, Jan 3, 2008 at 2:23:40 PM | HELP ME - export to .dwg problem
bimmonkey
What you have suggested is exactly what I have done ... seems that Revit is ignoring the "new" layer that I have created ...
Thu, Jan 3, 2008 at 2:39:04 PM | HELP ME - export to .dwg problem
NKramer
4 Stars: 9 Votes
Have you tried creating a new layer maping file? It might be that Revit is defaulting back to the AIA standard rather than using your modifications.
See File: Inport/Export Settings: Export Layers DWG/DXF...
Try editing that file and then save it under a differnt name. You should then be able choose that new file from the layer and property settings on the export options dialogue box.
If that doesnt work then Im not sure. Have you updated to the latest build, 08-3 (dont recall the number string)? You could also try seindg it to Autodesk/ your reseller and see what they have to say about it.
Thu, Jan 3, 2008 at 2:49:18 PM | HELP ME - export to .dwg problem
bimmonkey
I started with the AIA file ... saved as a new file name ... would hate to start from scratch ....
Will send this question to Autodesk retailer tomorrow ....
Not sure if I have the latest update ... but I'm pretty sure my computer is set up for auto-update.  I'll check on that now ...
Thu, Jan 3, 2008 at 3:03:22 PM | HELP ME - export to .dwg problem
NKramer
4 Stars: 9 Votes
I think that you actually have to download the build from autodesk or your reseller, uninstall the old revit and reinstall the new. So i dont think that it will auto update. Sometimes I find that these things are just quirks in the program...
Nick
Export 3d DWG issues
Fri, Jun 28, 2013 at 8:27:02 AM
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches?
Wed, Feb 11, 2009 at 4:42:25 PM
Export to dwg problem - I want it all in 1 file :) - please heeeelp
Wed, Jan 23, 2008 at 4:36:53 AM
EXPORT TO DWG - Problems
Wed, Feb 22, 2012 at 2:28:53 PM
Dwg export: revit 2013 ignoring subcategories
Thu, Jul 25, 2013 at 8:12:43 AM
Page generation time: 0.7158
