24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Fill colors in section
Fri, Dec 28, 2007 at 6:02:29 PM | Fill colors in section
cirocirociro
Our firm is creating a set of presentation drawings which require not only plan views that show the differentiation of open office space and circulation space (easy enough with a color fill in an area plan), but also to show this same differentiation in a building section view.  I have not come across any ways to create a color fill area in a view other than a plan (although you can tag a room in section, you can't give it a color fill).  I tried looking into creating a filled region with color, but it does not seem that you can create a colored fill pattern that is transparent.  Did not found an answer not even on the Revit 2008 tutorials
Wed, Jan 9, 2008 at 2:16:13 PM | Fill colors in section
LIZARD2806
3.5 Stars: 7 Votes
I cannot find any way to automatically create a presentation color fill, though it would be a worthwhile addittion to the next version of Revit.  You can, however create a transparent color fill.
While in your section, do the following:
1. From the Draftingmenu, choose Filled Region
2. On the Design Bar, choose Region Properties
3.  Click Edit/New, then Duplicate.  Rename the pattern to Color 1 (or whatever you desire)
4. Change the fill pattern to solid fill
5.  Change the Background to Transparent
6.  Change the color to whatever you wish.
7.  Click the OKs back to get you back to the drawing.
8.  Draw your region and finish sketch.
Unfortunately, you need to make a new region style for every color.
HTH
changing object fill colors
Sun, Oct 11, 2009 at 9:28:18 AM
Area Plans with Color Fill Through Walls
Thu, Oct 8, 2015 at 6:50:30 AM
Annotation fill colors.
Wed, Oct 5, 2005 at 6:23:11 PM
Colors and Printing
Thu, Jul 19, 2012 at 10:11:31 AM
Toposurface Fill Color in a Section View
Fri, Jan 30, 2009 at 9:28:10 AM
Page generation time: 0.7185
