47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Can't Edit Topo Pads
4 Posts No Rating |
I created a very simple topo pad and later needed to revise it. I can select it but it doesn't allow me to edit it. I can select the properties but there is no edit button to revise the profile in plan. Any thoughts??????????? Big Fan!
If you created the topo by using points, just click on the topo and edit should show on your options bar. Then you can just drag the points around , delete them or add new..
4 Posts No Rating |
Thanks for the idea but I created the topo using imported topo. The pad essentially created a flat square pad in which the building sit in. The problem is that I can'e edit the profile of the pad once it is created but in the help topics it tells me I can.
Topo PADS |
Sat, Sep 29, 2007 at 3:41:40 AM
Sloped inscribed building pads have topo 'walls' |
Wed, May 6, 2015 at 7:25:40 AM
Topography and pads trick |
Mon, Jan 14, 2013 at 2:53:18 PM
Pads and Phases |
Wed, Oct 28, 2009 at 4:09:21 AM
Pads/Phases AGAIN! |
Thu, Aug 9, 2012 at 3:14:53 PM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
