46 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> New Keyboard Shortcuts
Thu, Dec 27, 2007 at 10:02:00 AM | New Keyboard Shortcuts
Andrea1983
I would like to have a keyboard shortcut for a few regularly used annotation symbols,  but I can't figure out how to type it in to the KeyboardShortcuts.txt file.  Is this possible and how?
Thu, Dec 27, 2007 at 12:40:20 PM | New Keyboard Shortcuts
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
Well, I assume you found the KeyboardShortcuts.txt file. All you have to do is open it up using notepad. It should contain a bunch of lines formated something like this:
;"" menu:"File-New-Project
 All you need to do is find the function you are trying to create a shortcut for on the right side of the list, and then type the keystroke between the quotes, and then save. So if I wanted to make a shortcut for New Project be NP I would modify the line like this:
; "NP" menu:"File-New-Project"
Hope that helps!
Edited on: Thu, Dec 27, 2007 at 12:41:47 PM
Thu, Dec 27, 2007 at 1:14:56 PM | New Keyboard Shortcuts
Andrea1983
Thanks, I knew how to ad the two letters to a shortcut, my question was is it possible to create a new type of command, like a specici symbol or component for a type command
Thu, Dec 27, 2007 at 1:22:51 PM | New Keyboard Shortcuts
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
I think you can only create shortcuts to the commands listed in the KeyboardShortcuts.txt file, but that would be a great feature.  Maybe someone else can prove me wrong!  Otherwise, that might be a good feature to request from autodesk.
Thu, Dec 27, 2007 at 1:26:21 PM | New Keyboard Shortcuts
Andrea1983
THANKS
Some Keyboard shortcuts not working?
Tue, May 5, 2009 at 2:52:55 PM
Keyboard shortcuts
Thu, Jul 3, 2008 at 11:14:44 AM
Keyboard Shortcuts Won't Open/Show
Tue, Feb 26, 2013 at 11:09:04 AM
Keyboard Shortcuts??????
Thu, Jun 12, 2008 at 9:19:18 AM
Looking for a few handy keyboard shortcuts
Mon, Sep 27, 2010 at 8:21:51 PM
Page generation time: 13.5681
