69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window Sills in Revit Arch. 2008
Wed, Dec 26, 2007 at 10:14:42 PM | Window Sills in Revit Arch. 2008
eltazar
Firstly thankyou to all the active people in these forums, im very new to Revit and stuggling to get my head around it and youve all been helpful thus far.
Im tearing my hair out with showing window sills on brick veneer walls. I have standard window family that is pretty good the only thing that i need to change is getting it to show a window sill for brick veneer walls. I have placed a sweep to create the sill but i cant seem cut a void back into the basic wall so that the sill carries through to the frame as it should. I would really appreciate if some could post some step by step instructions.
 I have attached my standard family if that helps.
Thu, Dec 27, 2007 at 9:12:45 AM | Window Sills in Revit Arch. 2008
UserError
UserError Avatar
3 Stars: 1 Votes
i opened your file and took a look. i am not sure if this solution is what your looking for but creating a viod form won't work. you need to edit the opening cut of the window itself.
 i was able to get this to work by first deleting the opening that was there and then adding a new opening, constraining it 4" or so below the bottom reference plane.
window sills
Sun, Jun 18, 2006 at 5:16:18 PM
Stone Window Sills
Wed, Jul 16, 2008 at 9:44:34 AM
Creating Window Sills
Tue, Jul 3, 2012 at 1:26:40 PM
Window sills and head
Thu, Apr 7, 2005 at 9:11:04 PM
Window tag gone on copied windows
Tue, May 25, 2010 at 3:30:37 PM
Page generation time: 3.0956
