Forums >> Revit Building >> Technical Support >> Ramp Boundary Lines / Run Lines / Landing Lines
11 Posts No Rating |
I am trying to create a rather simple ramp. I can type in all my level heights and stuff..... and then I can basically drag the ramp outlines until my ramp is finished. However, if i try to do any changes to the boundary lines or any lines for that matter i get this warning....."Stairs require no more than two boundaries (chains of one or more Boundary Lines)." I was wondering if some one could basically explain what this warning is talking about ..... im not really getting what they are trying to tell me. Thank You
Typically, that error message appears when you have too many boundary lines. On a straight ramp, there should be only two boundary lines, paralell with the run of the ramp and a riser line at the top and bottom. Try drawing the ramp from scratch as well instead of using the default RUN command (the run command is evoked as soon as you click ramp, and you just tell it a start point and end point). You can create the ramp using just four lines. Two for boundary (sides of the ramp) and two riser lines (start and finish). HTH
**Using Revit Architecture 2009, 2011, and 2012** |
As usual. The solution is just a little more simple than what I thought it would have to be. Thanks, Ben
1 Posts No Rating |
The problem resolve is eliminate the boundaries paralell to midline (blue line) and select one of the perpendicular lines to blue line, next step lengthen off the perpendicular lines at desired distance and finish the process. regards
L Shaped Ramp with 5'x5' Landing |
Tue, Dec 11, 2012 at 4:28:00 PM
Ramps Help Please???!!! |
Thu, Apr 15, 2010 at 7:07:34 PM
Ramp error "Stairs require no more than two boundaries....) |
Mon, Apr 25, 2016 at 9:02:19 AM
Remove object lines/boundary lines? |
Thu, Jan 10, 2019 at 2:00:04 PM
Parallel Boundary Lines? What do these mean? |
Tue, Jun 28, 2011 at 9:36:02 AM
Members: | 2101409 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
