50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stairs and ramp
Wed, Dec 26, 2007 at 12:40:08 PM | Stairs and ramp
BRIANDHADLEY
1 Stars: 1 Votes
Using Revit Architecture. Is there a way to create a stairs, landing and a ramp like in the attached pdf all in one step.  I want my handrail to be one continuous piece.
Wed, Dec 26, 2007 at 1:20:06 PM | Stairs and ramp
Yes, I think you can but it is not as easy as you would like.  Make your ramp and stairs then delete their railings.  Make a new railing by sketching your rail in plan as line segments.  You will have to determine the corect horizontal intersection point for each segment.  For the rail at the stairs, choose slope by host and pick the stairs.  For the flat section, pick no slope and for the ramp portion, set it to slope and set this amount.
Let us know what you learn.
Wed, Dec 26, 2007 at 5:22:20 PM | Stairs and ramp
BRIANDHADLEY
1 Stars: 1 Votes
Apparently you can't host the rail to both the ramp and the stairs.  Is the ramp tool the way to go?  I can't join any geometry to the ramp and it doesn't display the material in the floor plan.
Ramp error "Stairs require no more than two boundaries....)
Mon, Apr 25, 2016 at 9:02:19 AM
problem with stairs and ramp?HELP
Sun, Jun 1, 2008 at 11:49:57 PM
Helical Ramp
Wed, Mar 10, 2004 at 8:51:07 AM
A ramp!
Thu, Jan 21, 2016 at 11:37:45 AM
Ramp breaklines
Tue, Apr 16, 2019 at 5:37:49 AM
Page generation time: 2.1807
