56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> wall with bump
Fri, Dec 21, 2007 at 1:18:04 PM | wall with bump
jbenedetto
I have been trying to draw a wall with a bump it, where about 5 feet of the wall is 9" thick, and the remainder is 4" thick. I've tried creating an in-place wall, but it doesn't clean-up with other walls, and doesn't have the same properties as the other walls...
 Does anyone know an easy way to do this?
 I've attached a picture showing the in-place wall I created to clarify what I'm trying to accomplish.
thanks for any help.
 jb
Fri, Dec 21, 2007 at 1:22:08 PM | wall with bump
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I would make them as two wall types. One with the 4" thickness and the other with the 9" thickness and draw them with the faces aligned on the common side.
Fri, Dec 21, 2007 at 1:30:42 PM | wall with bump
jbenedetto
works perfect. thanks!
jb
Decal Bump Pattern
Tue, Oct 30, 2012 at 12:00:16 PM
Trimming Wall Layers
Thu, Jan 4, 2018 at 9:30:10 AM
Changing the scale of a Bump image for rendering
Mon, Sep 26, 2016 at 1:03:42 PM
My bump lines are too thick and heavy. [ 1 2 ]
Thu, Aug 11, 2016 at 2:45:39 PM
21
wall clean-up
Tue, Jul 29, 2008 at 10:38:27 AM
Page generation time: 0.6700
