54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Ceiling Fans in Elevations
Thu, Dec 20, 2007 at 11:01:06 AM | Ceiling Fans in Elevations
rcobbjr
3.5 Stars: 3 Votes
I have created interior elevations of my greatroom. I have two ceiling fans in the space. In the South Interior elevation, you can see the ceiling fan (Greatroom_Fans.jpg) but in the North elevation you cannot see the fans (Greatroom-NoFans). What could be causing this to happen? See attachments.
Thu, Dec 20, 2007 at 12:46:26 PM | Ceiling Fans in Elevations
Is your ceiling fan family 2d or 3d? Either way, 3d or 2d, for 3dis it set to show in side views as well as front back, for 2d, is the symbollic lines drawn in both front and side views?
They appear to be 3d.  Are these a 3d cad import?  (I think so.)  Try putting an invisible circle in plan of your family that is the diameter of the fan.  REVIT needs to intersect the family in order to show it.
Edited on: Thu, Dec 20, 2007 at 12:49:04 PM
Wed, Dec 26, 2007 at 10:45:17 AM | Ceiling Fans in Elevations
JHanby
3.5 Stars: 3 Votes
Where is your section line?  Is it going through the middle of the ceiling fans?  If it is to the side, you would only see it in one view.
dropping in light fixtures and ceiling fans into RCP's
Mon, Aug 11, 2008 at 9:19:45 AM
Ceiling Fans in MEP?
Tue, Mar 24, 2009 at 5:32:49 AM
placing ceiling lights
Fri, Dec 14, 2018 at 3:21:47 PM
spot elevations - lay-in ceiling
Thu, Oct 27, 2005 at 2:49:21 PM
Anyone have a WALL-mounted Ceiling Fan Family?!
Wed, Sep 18, 2019 at 8:43:01 AM
Page generation time: 0.4731
