46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> working with massing - help! (Revit Architecture 2008)
Hello, I am new to revit (architecture 200 and have been doing a lot of turorials. I have one on massing that I got from the Autodesk website (Using Massing Tools). I have two issues; first is that the template you are asked to use is not available to me (Imperial\i_massing_Start.rvt.) I have tried to load this template, but have not found it. I have resorted to using other available default templates. A bigger problem however is that when finished working with a mass and completing a save, when the drawing is opened back up the completed mass is gone! If you look at the thumbnails prior to opening it looks like where you left off, but press "open" and presto - no mass's. Any and all help appreciated, Thanks, Rich
![JAMESHGRIMES Avatar](user_avatar/17328.jpg)
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
Try opening the file and going to View-->Show Mass.
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Do you have the "show mass" button turned on in your views? The default is for it to be off.
Thanks guys! That solved my problem. Just another R.O.S. situation - rookie operator syndrome. Cheers, Rich
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
If you're dabbling with Massing (!), you may find this of interest.... http://www.revitzone.com/index.php?option=com_content&task=view&id=203&Itemid=34 Regards, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
Massing Printing Problem-solve (sort of)-Revit Architecture (2008) |
Fri, Aug 24, 2007 at 3:15:20 PM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008 |
Tue, Nov 20, 2007 at 12:37:43 PM
Massing Tutorials (Revit Architecture 2013) |
Thu, Sep 13, 2012 at 4:17:47 AM
curtain system by face in massing HELP |
Fri, May 23, 2008 at 8:13:34 PM
Crashes with Architecture 2008 |
Mon, Oct 22, 2007 at 6:48:44 PM
12
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
