81 Users Online (80 Members):
Forums >> Revit Structure >> Technical Support >> Walls cutting slabs
Is there any way to have walls cut slabs? I have a condition where a 8" CMU wall is on a 12" foundation wall, and top of concrete is 8" below top of slab, so the CMU goes through the slab. I know I could model the slabs around the CMU so in section it shows correctly with a 1/2" exp. joint between the slab and CMU, but I would rather just have the walls cut out the slab instead of editing the slabs.
Couldn't find the edit post otion for some reason, but here is a dwf showing what I need.
revit will cut the slab out of the wall but not the wall out of the slab.... dont know why. The only way I can think of is to add an opening and constrain it to the outside of the wall. Let me know if you can find a better way. BTW to edit a post click on the #1 (or approperiate #) and then there is a little drop down. If its your post then you can edit it. Took me a while to find that too. HTH Nick
I don't think I get your problem right ... but as I understood I think making a vertical opening constrained to the outside of the wall is the best solution ...
----------------------------------- Moh_Adnan_Alj |
Hey, this thread has more than one year... I think he was already figure out....
" Hey, this thread has more than one year... I think he was already figure out.... " ditto
LOL...
Befff .... Sorry guys !!! I didn't know that , I just bumped into that thread by coincidence..
highrise towers slabs-walls joining |
Tue, Jun 1, 2004 at 6:18:09 PM
Window not cutting furred wall |
Tue, Feb 14, 2012 at 12:56:04 PM
Slabs in some views showing up as tone. |
Wed, Sep 8, 2010 at 11:17:03 AM
Floor slabs showing dashed instead of Solid |
Wed, Jun 5, 2013 at 5:53:00 PM
12
Windows not cutting through walls |
Mon, Nov 21, 2016 at 9:37:41 AM
Members: | 2057587 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
