117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Sections
Mon, Dec 17, 2007 at 8:55:20 AM | Wall Sections
icestunna
Does anyone have a clue as to the simpliest way of setting up wall section in Revit. A full wall section including the different materials and how the actual roof sits on the roof and also the floor slab as well. If anyone has any idea or clue as to how this process is executed please reply ASAP!
Mon, Dec 17, 2007 at 12:15:15 PM | Wall Sections
apsis
  1. cut sections on the plans
  2. go to that view- change the view level to fine.
  3. assuming your walls and roofs reflect the materiality of their construction (eg, 1.5" metal standing seam on 3/4" rigid insulation on 3.5" cold formed metal framing... etc) you can then use detail components to lay over the top of the model. Use components as much as possible- stay away from linework as much as possible.
  4. You can then leave the underlain model on or off- but leaving it on makes for a nice reference- if something moved- it will become visible in the view.
From Wall Sections to Drafting Views
Fri, Sep 25, 2009 at 10:22:08 AM
Wall Sections disappearing?
Tue, Aug 21, 2007 at 1:13:29 PM
Custom Wall Sections
Sun, Aug 7, 2005 at 10:05:54 PM
Problem with wall sweep show on wrong sections
Wed, Mar 22, 2006 at 5:37:32 AM
Revit 2017 Mising Wall Sections
Mon, Jul 18, 2016 at 5:53:08 PM
Page generation time: 0.9085
