59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> nested array in louvres
29 Posts No Rating |
hey crew... just did mr spots tutorial on nested family arrays etc... did the trick brilliantly.... but... i was after the louvres in my array to rotate on a central axis, not the corner of the louvre... and i also need to create an eliptical louvre and im have a little trouble making it rotatable in the family... any ideas... thanks
135 Posts No Rating |
interesting, working on louvres all the time, worked this out once but not with nested families, could you send me the link for the tutorial?? E
23 Posts No Rating |
If I wanted to start a louver family can I use a revit default window family? if not which template do I use? Thanks.
Primary: Revit Architecture 2008\AutoCAD 2007Old Versions: Revit 9.1\AutoCAD 2002 |
http://www.revitcity.com/tutorials/arrays_and_nested/ sounds like no one knows then.... this is the tute from mr spot i think.... worked a treat... but let me know if you find out how i can change the louvre to an eliptical one.... cheers peoples
![RolyNZ Avatar](user_avatar/27025.jpg)
![4 Stars: 3 Votes](/images/stars_4.gif) |
I did this one using a sloping glazed roof item. I use an aerofoil shaped profile with a parameter to adjust the angle. Then create a mullion using the aerofoil, then use a curtain system etc. I only did it once & it worked for what I needed. Check it out... - sorry I am not too sure how to extract the actual model bits out of Revit to share with you!
www.Crawshaw Architecture.co.nz |
family with array question |
Tue, Dec 22, 2009 at 6:34:30 AM
Is Solution to Creating a Parametric Polar Array? |
Tue, Oct 22, 2013 at 8:40:06 PM
curtain wall pannels how to creat louvres?? |
Wed, Jul 21, 2010 at 4:40:51 AM
Array leaves horizontal |
Fri, Sep 19, 2008 at 4:32:29 PM
Array Parameter within Family |
Thu, Aug 7, 2014 at 8:25:09 AM
Members: | 2022368 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
