Forums >> Revit Building >> Technical Support >> Phases and linked files
2 Posts No Rating |
I am developing a master plan which is made up of several building types, each repeated multiple times. Each building type is a separate Revit file linked into a main host file, which also includes the sitework for the master plan. I want to show the buildings in separate phases, showing the development of the master plan over time. I understand how to set up phases in a single file, but is there a way to associate phases with linked files? We can do a workaround by turning specific links on and off in views, but I would prefer to do it by phasing. Thanks for any suggestions!
For each view, look under VG - REVIT LINKS - Display Settings - Custom - Basics - Custom and set your phase.
2 Posts No Rating |
That method only gives me the choices of "By Host View," "Last," "Existing," and "New Construction". I created 4 phases, named Phase 1, Phase 2, etc. - but these phases do not show up as choices under VG-Revit Links. I want to associate the link with a specific phase. Using the VG method seems to associate the link with whatever phase the view is set to; changing the phase in View Properties would then change what phase the link is associated with.
multi building site with phases |
Thu, Oct 25, 2012 at 10:35:28 AM
Can't filter "Phase Created" in MTO for linked Revit files? |
Mon, May 12, 2014 at 7:01:46 AM
autocad linked files and refresh |
Tue, Apr 7, 2009 at 2:12:37 PM
View Properties of Linked Revit Files |
Mon, Feb 15, 2010 at 9:56:23 PM
Linked Files Revit 2009 |
Wed, Aug 31, 2011 at 3:27:12 PM
Members: | 2100373 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
