72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> shading with edges, side in shadow comes out white
Fri, Dec 14, 2007 at 11:12:56 AM | shading with edges, side in shadow comes out white
tdincer
I am doing basic perspectives of my building, just shading and edges and no advance shading turned on.  However, on one side the glass shows up green and the other side it shows up white.  Green is the color assigned to the glass.
 The side that is green is where the sun "would be" hitting if I had the sun/shadow settings turned on.   The side that is white is the side that "would be" shadow.
 How do I get both sides to render the same?  Can I set a default sun per view?
See the attached images for clarification.
Thanks
Shading w/ Edges Color Differences
Thu, Jul 23, 2009 at 2:18:44 PM
Doors make a gray shadow in Sections
Wed, Apr 7, 2004 at 10:39:44 AM
shading with edges problem
Wed, Nov 17, 2010 at 6:49:50 AM
Shadow is not visible when rendering
Wed, Mar 19, 2008 at 11:23:55 AM
'shading w/Edges' Elevations
Thu, Jul 22, 2004 at 10:50:49 AM
Page generation time: 0.4053
