72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Structural Trusses not attaching to walls
Thu, Dec 13, 2007 at 4:12:02 PM | Structural Trusses not attaching to walls
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I used the Structural Beam system tool for our 20" trusses below the roof.  I then rotated the system accordingly and it won't trim to the walls.  I tried to cut geometry but it doesn't work (I can't even select it).  I've also tried to join geometry to wall (again, I can't even select the trusses).  So what I did was a work around aligned the edges to hide inside the wall.  The bottom is not inthe wall but I can hide that with a ceiling.  But this isn't the correct way to assemble it.  Does anyone know how I can correct this problem so it is built correctly??
Denver, CO
Revit Architecture
Fri, Dec 14, 2007 at 10:00:55 AM | Structural Trusses not attaching to walls
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
PLEASE?!?
Denver, CO
Revit Architecture
Fri, Dec 14, 2007 at 10:54:26 AM | Structural Trusses not attaching to walls
dano3d
3.5 Stars: 3 Votes
Dude,
check out the attached rafter family that I found at this website...
It may work for you in some way?
Structural trusses invisible when rendered in 3d camera vew
Sun, Oct 3, 2010 at 12:15:19 PM
I am having trouble loading the structural trusses
Thu, Oct 7, 2010 at 3:58:09 PM
Attaching trusses to linked roof plane (Revit Structure)
Thu, Jan 14, 2010 at 8:52:00 AM
Attaching Structural Col to Structural Slab
Mon, Apr 30, 2007 at 10:05:24 PM
Attaching walls to a Linked Structural Model slab
Mon, Nov 18, 2013 at 11:13:38 AM
Page generation time: 0.7469
