Forums >> Revit Building >> Technical Support >> Wall Visibility
Using Revit Architecture. In the attached plan I have a roof plan with the floor plan underlayed. Can anyone tell me why some of the walls are not visible?
What attached plan? In which view can you not see the walls?
I will try to attach it again. The roof plan is the what my question pertains to.
Here is a pdf of the roof and the floor plan. Has anyone experienced this problem?
Looks like only the exterior walls are not showing up. Are they on a seperate workset that is turned off?
No. All on same workset.
Are the wall attached to the roof?
Yes they are. Does it make a difference?
Do you want to see your ghosted walls in your roof plan?
Yes
I am not sure on this problem, but have you tried detaching from the roof? I would recommend checking your visibilty/graphics overrides.
The problem seems to be caused by the walls being attached to the roof. But I need them attached to the roof for my elevations and 3d views.
One idea is to detach for that view, if the walls can be seen after detaching, and reattach for the other views when you print. It is extra work, but I have run into doing extra things in Revit just for graphic reasons.
Wall Core Visibility |
Thu, Oct 9, 2008 at 11:53:58 AM
Turn off wall visibility on upper floors... |
Fri, Mar 4, 2011 at 2:24:23 PM
Wall Component Visibility |
Tue, Sep 9, 2008 at 10:03:23 PM
Wall section visibility |
Thu, Nov 16, 2006 at 12:27:58 PM
Punched hole in shear wall visibility issues |
Tue, Dec 26, 2006 at 4:19:43 PM
