54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Lines hidden with the line tool - how to see them again?
Wed, Dec 12, 2007 at 2:43:43 PM | Lines hidden with the line tool - how to see them again?
Oktober
On some of my elevation i have hidden some lines where the first floor and second floor walls join, but i have sometimes noticed i have hid to many lines.
When i click the show hidden elements etc it doesnt show these, how would i see them?
Thu, Dec 13, 2007 at 12:13:03 PM | Lines hidden with the line tool - how to see them again?
kesflower
3.5 Stars: 11 Votes
You didn't actually hide the lines when you used the linework tool, you changed the lineweight (if you can't see them I'm assuming you changed the linewieght to invisible lines).  To make those lines visible again, use the linework tool again, but this time change the lines you want to see to one of your visible linewights.  The linework tool will auto highlight the lines, so you can tab through all the ones you don't want to see and only change back the ones you do want.
 Hope that helps, best of luck
Ruth Rau
Main Street Architecture, P.C.
Hidden Line Tool not working through links.
Tue, Jul 20, 2010 at 9:06:09 AM
Show Hidden Lines Tool and Detail Elements
Fri, Nov 22, 2013 at 8:48:51 AM
Hidden Lines disappeared from all my Elevations
Fri, Mar 1, 2013 at 12:37:05 PM
Line Work Tool
Wed, Sep 26, 2007 at 1:40:35 PM
Line Styles Adjusting with Wall Hidden Lines?
Mon, Mar 12, 2018 at 12:58:30 PM
Page generation time: 0.9803
