Forums >> Community >> The Studio >> Curved Masonry Walls
My question is related to an actual masonry wall, not a Revit wall. Do problems often arise from curved masonry walls, i.e. joinery, cost, or anything else. I have not had experience from a actual mason, but a long 160' curved wall would seem to be better replaced by a diagonal.
With actual curved walls, your cost and joinery and the difficulty of integration with other walls is entirely dependant on the skill of your mason and his/her crew. Most masons will charge a premium for a curved wall because of the care they need to take to get it right, but if you've got a good mason, that upcharge will mean that the work is of such a quality that there will be minimal problems with integration of other wall types. I think that if you want a curved wall, design a curved wall and then get several prices from several masons. If you anticipate that in your area there will be too much of a price premium for that curve, then think ahead and make mental note of how you would need to design it with a diagonal wall. But if you're using Revit for the redesign, it shouldn't take too much to change the wall at a later date. Design what you want, you may be surprised by the skills of the craftsmen around you!
Ruth Rau Main Street Architecture, P.C. |
concrete wall and masonry wall to have different lineweights |
Thu, Jan 6, 2011 at 12:39:04 PM
Creating different Masonry walls with different finishes |
Sat, Feb 4, 2012 at 9:07:02 PM
Aligning hatch pattern on elevations |
Wed, Jan 30, 2008 at 3:29:51 PM
masonry walls? |
Tue, Jun 22, 2010 at 5:35:51 PM
curved curtian walls |
Mon, Nov 13, 2006 at 6:19:28 AM
Members: | 2119153 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
