Forums >> Revit Building >> Technical Support >> Roof Material
Using Revit Architecture. In a roof plan how do you turn off the shingle roof pattern?
In your roof plan, go to View Properties - Visibility/Graphics Overrides - Model Categories - click to highlight Roofs, then under Projection/Surface - Patterns, click Override and in the window that pops up, unclick the Visible checkbox. This is a new placement from previous versions. You turn off floor surface patterns and wall patterns in elevations the same way.
Ruth Rau Main Street Architecture, P.C. |
I don't have the Projection/Surface Pattern option.
When you highlight Roofs, the two columns to the right are your Projection/Surface pattern options. Click Override in the 2nd column to the right.
Got it. Thanks, I guess I'm just blind.
Adding Material to Roof trim? RAC 2009 |
Mon, May 12, 2008 at 1:57:11 PM
Standing Seam Metal Roof Material |
Tue, May 19, 2009 at 9:58:49 AM
Changing roof colour / material |
Wed, Feb 14, 2007 at 6:18:21 AM
rotate material on fascia |
Mon, Nov 23, 2015 at 10:29:04 AM
Flat Concrete Tile Roof |
Tue, Oct 29, 2013 at 10:31:53 AM
Members: | 2116517 | Objects: | 23196 | Forum Posts: | 152302 | Job Listings: | 3 |
