81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> window and door schedules
Mon, Jan 5, 2004 at 10:36:43 AM | window and door schedules
Bimman
Bimman Avatar
1 Stars: 2 Votes
on the window and door schedules i have sorted by level in order to show what level they are on. can i split the schedule so only each levels windows appear on there own respective sheet when i sert the schedukle for that floor on the same sheet. i.e. first floor sheet would have a schedule with first floor windows only. same idea for doors.
PWD
Mon, Jan 5, 2004 at 11:30:05 AM | RE: window and door schedules
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
you would create different window schedules for each level. Use the filter command in your schedule properties window. Filter by window where the level equals your level.
Hiroshi Jacobs
The Catholic University of America
Tue, Feb 3, 2004 at 2:28:09 PM | RE: window and door schedules
Bimman
Bimman Avatar
1 Stars: 2 Votes
can you explain a little more on this. i am just now getting to this and still having trouble.
PWD
Tue, Feb 3, 2004 at 3:44:21 PM | RE: window and door schedules
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
start a new schedule and call it Level 1 Windows or however you want to name it. Select the fields you want including level. When you go to the schedule properties window, there will be a tab called "filter" filter by level and only the windows on your level will show in that schedule. You will have to create separate window schedules for each level.
Hiroshi Jacobs
Tue, Feb 3, 2004 at 4:03:05 PM | RE: window and door schedules
Bimman
Bimman Avatar
1 Stars: 2 Votes
worked great. i tried to do it with doors, nut there is no filter by level for the door schedule is that something i need to add or do you know if it can be done.
PWD
Tue, Feb 3, 2004 at 4:10:57 PM | RE: window and door schedules
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
works for me... make sure you add level as a field
Hiroshi Jacobs
Wed, Feb 4, 2004 at 7:02:49 AM | RE: window and door schedules
Bimman
Bimman Avatar
1 Stars: 2 Votes
after i popsted i figureed outthat is what i didn't do. thanks
PWD
Managing Door/Window Schedules
Mon, Jun 18, 2012 at 7:17:06 AM
Wed, Apr 14, 2010 at 5:23:52 AM
Putting Window and Door Tags in Door and Window Schedules
Thu, Mar 12, 2009 at 1:38:06 PM
Tue, Jun 5, 2012 at 7:22:39 AM
phasing in window & door schedules
Tue, Mar 16, 2010 at 3:27:39 PM
Page generation time: 2.2112
