Forums >> Revit Building >> Technical Support >> appearance of line types of existing objects in a "new construction" views
5 Posts No Rating |
I am working on a renovation of an existing building. I have modeled the existing conditions and have begun to add new elements. The phase of my plan view is now listed as "new construction". All of the existing elements have greyed out which is exactly what I would want.
The problem is that, revit has converted all of my lines into a solid line type and I can not seem to change that. I have several arched openings which should be drawn as overhead dashed lines. Unfortunately, it is solid and I can not change it. Can anyone suggest a way to take control of these line types?
Don't phase the lines... Draw them in the new construction phase and just set the line type to be grey for instance...
5 Posts No Rating |
Ok, I won't phase my existing lines, but I still want to separate my existing walls from my new walls. How do I change the color of certain walls, but not others in a single view?
5 Posts No Rating |
Mr. Spot,
I just discovered the "Linework" command. If I am understanding it correctly, I am able to choose specific lines in a view and assign a new line type to it.
This seems to allow me to keep my existing walls as existing instead of moving them to new construction. Once they have become grey solid lines in my new construction view, I can just go in and manually choose certain lines to turn into grey dashed lines.
Do you see any problems in doing this?
admin
Klackey, that is exactly the way you should do it. You don't want to get rid of your phasing for more reasons than just this issue. Phasing allows you to have current and correct information in all of your views, (plans, sections, elevations)
Hiroshi Jacobs
The Catholic University of America |
Phase Line Weights |
Tue, Apr 26, 2011 at 7:14:33 PM
future phase line type |
Thu, Sep 25, 2014 at 3:20:58 PM
new line type / existing dtl component |
Wed, Nov 25, 2020 at 9:53:14 AM
Existing Elevations not Referencing Existing Plans |
Thu, Dec 5, 2013 at 3:57:29 PM
Existing wall assembly visable in New Construction phase |
Wed, Nov 2, 2011 at 5:49:09 PM
Members: | 2114828 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
