66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> How to have a door tagged as a window?
20 Posts No Rating |
Hello, Using Revit 2008 here. Am a beginner with only three weeks experience now and its been an interesting one. The basics I have pretty much learned a lot about. But the real complex things are still complex. I loaded the Single Panel Fixed door from the Revit web library and it is used as a door object. But since it is a fixed panel and our office standards consider it to be tagged/identified as a window. Of course, I tried loading it the same file through the window command and no luck. I have tried playing around with shared parameters and could not figure it out. Could someone help me out with this one? A sidelight is considered a window so why not the fixed door panel? Thanks!
![JAMESHGRIMES Avatar](user_avatar/17328.jpg)
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
What you need to do is Open the Fixed panel Family. Go to Settings menu-->Family Category and Parameters and checkmark "Window" category. Save and reload the family into the project and it will tag as a window.
Wow, the little things like that really help a LOT. It worked and thanks!
Need help tagging/scheduling a door with a sidelite |
Tue, Jun 8, 2010 at 2:15:22 AM
Window and Door OverView Sheet |
Sun, Apr 16, 2006 at 8:51:46 AM
Door and Window Scheduling - showing the door and window as an image. |
Thu, Feb 11, 2016 at 7:50:51 AM
Door and Window types |
Thu, Nov 23, 2017 at 11:19:52 AM
Calculated Value - Door Schedule Work Around? |
Mon, May 18, 2015 at 12:56:02 AM
Members: | 2016941 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
