Forums >> Workflow & Implementation >> Hardware >> Worth upgrading or buy new?
My current laptop is getting tired i think. Performance has dropped significantly these last few months and aside from doing some housekeeping, i'm contemplating adding some ram. The current configuration is 1 gig and the video card is an ATI Mobility™ RADEON® X300 with 64 MB of dedicated video memory. To swap the 1 gig for a total of 2 gigs (max capacity) will run about $340 US. Running XP but also am hooked up to a LAN with revit files on server. The alternative is to hold out till spring and upgrade to a current configuration with 4 gigs and Vista. Hoping that maybe Revit will be 64 bit functional in next release, (doesn't look good). Any advice?
If you have the choice go with XP x64. Revit actually runs better on it even though its not 64 bit, you will be ready for a 64 bit release, and right now XP x64 is a better platform than is Vista 64. Other than that go with 4gb of ram, and I would go with NIVIDIA over ATI at the moment. You will be better off going with XP 64 not vista though. Dual core CPU will help out as well.
11 Posts No Rating |
I would not wait for Revit to get up to speed with Vista, go with a XP based 64 bit system. Vista won't work with most office programs anyways. Get at least 3.5 gig of ram. Once you have your new CPU box, enabled the 3g switch, do a search and you will find how to do this. Get a computer that the video card has its own memory on its board so that it is not robbing your ram. Get a network card that is Gigabite speed. Get a monitor that is wide screen and 21" min. Dual mointor setup say a smaller 17" non wide screen, next to the big one is really helpfull. Also on you new system this below was very helpful with our file saving and speed - our files are over 80,000 kb to 190,000 kb Set up your virtual memory to use you ram and not your hard drive as much for the data swapping - go to system properties, open advanced tab, open preformance options tab, write down your existing settings. Set up virtual memory to custom - initial size - 4096, max size 10240 Your network is probally not helping, as you files get biggger and you have more users it can get really bogged down. Each of our work stations are directly wired to the server on cat 5e, no hubs in the way. Our network is all Gigabite cables, jacks, plugs, and hardware - just updated everything for Revit file sharing on our new Raid server. Big Bucks $$$$ were invested - yikes there goes my bonus this year!! Switching servers is a big deal for Revit!! Be sure to get professional help - contact autodesk and get an IT person who really knows what they are doing and are expereinced with Cad based programs. We were the first to do this and it was really dicy at times. Good luck My system is XP service pack 2 3.60 GHZ Xeon CPU 3.25 Gig Ram chug a chug along fairly well ...
If you install XP x64 there is no need to have at least 3.5 gig which you shouldnt ever have anyway, 3.5 gig over 2 or 4 dimm wont work efficiently. Go with XP x64 and put 4 gb or more of ram, there is no need on XP x64 to put a 3 gig switch on your computer because it is a 64 bit OS so there is no need. Vista actually has very few problems with office programs anymore, but still XP x64 is the way to go because of user interface. Building a 4+ gig computer with a good NIVIDIA video card, dual core CPU, and a decent hard drive wont run you over $1000 if even that now. If you are planning ahead go with XP x64 not regular XP, it will be alot better in the long run. 3.25 gig isnt going to be very well used by XP, as a not if you put ram on a computer it should be able to be evenly spread across 1, 2, or all 4 dimms avaliable, never 3 dimms, and never unevenly as the computer wont use this effectivly at all, and your just wasting money. Revit 2009 is roumered to be x64 but they may not be able to pull it off, x64 Revit will be released definatly by Revit 2010. Mine as well get a 64 bit OS now which Revit runs better on anyway, and also be prepared for when it goes 64 bit. Regular XP and any version of Vista is not the way to go right now.
Thanks for the replys. I was discussing this with our network guru and we have been monitoring the memory usage as well as VM size as the machine acts as if it is swapping out a lot. My VM is set for 2 gigs (double the ram) and the mem usage for revit rarely gets above 1/2 gig but the VM is approaching a gig. We thought maybe we have too much space allocated to VM and the system is using it over the RAM just cause it's there. I think i will change the swap file size to 1 1/2 gigs and see if i get any "out of memory" errors. I'm also getting an occasional CPU use of over 50% so i think maybe the 1.73 ghz processer is overworked too. I use 2 monitors now which is good and bad. I find that i have so many programs running that it's probably not helping but as one program is thinking, i work on another so overall, i've convinced myself i'm more efficient. Great advise on the OS and video card. i will keep that in mind when i get the new system. I really like the laptop though so i may not be able to get everything. I will forward all this to the network guys as i never even considered that as a weak link. Thanks again.
If you have two monitors your video card will split the memory between the two. bad for speed.
upgrading from 8.1 to 9.0 |
Fri, Jul 28, 2006 at 10:19:03 AM
thinking about upgrading...need help!! |
Sun, Jul 29, 2007 at 9:45:06 AM
upgrading worksets to new revir version |
Wed, Jan 11, 2006 at 6:11:06 PM
Is it worth the upgrade |
Wed, Apr 26, 2006 at 2:07:12 PM
cheapest way to buy Revit Architecture |
Tue, Apr 24, 2012 at 6:02:36 AM
Members: | 2100741 | Objects: | 23171 | Forum Posts: | 152296 | Job Listings: | 3 |
