26 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Remove Ground Poche/fill pattern
Wed, Dec 5, 2007 at 6:15:50 PM | Remove Ground Poche/fill pattern
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
In elevations showing the Topography...how do you remove the poche pattern?  I tried to change the material but there is no cut pattern assigned to the material.  The poche is still showing up?
Denver, CO
Revit Architecture
Thu, Dec 6, 2007 at 8:31:30 AM | Remove Ground Poche/fill pattern
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
The method I use is to right click on the Topography and Overide By element. This will allow you to make the cut pattern invisible.
Thu, Dec 6, 2007 at 8:21:16 PM | Remove Ground Poche/fill pattern
LIZARD2806
3.5 Stars: 7 Votes
if your elevation line is not cutting the topo, you also need to change your projection pattern.
Stiar cut pattern or fill pattern.
Sun, Feb 19, 2006 at 11:46:36 PM
Remove Fill Pattern
Tue, Jun 2, 2015 at 8:25:45 PM
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Walls, Floors and Roofs to show hatch pattern AND color poche?
Sun, Apr 29, 2012 at 12:24:19 PM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Page generation time: 0.8422
