123 Users Online (122 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Structural beam system visibilty
Wed, Dec 5, 2007 at 11:31:48 AM | Structural beam system visibilty
sgeelen
I find that structural beam systems members show in plan view even when outside of view range.
Any thoughts on how to fix this apart from manually hiding all member instances in the beam system.
Cheers
Stefan
Wed, Dec 5, 2007 at 12:40:40 PM | Structural beam system visibilty
LIZARD2806
3.5 Stars: 7 Votes
I can;t duplicate this.  Can you give a little more detailed explanation?  or you may wish to just post a reduced file (just walls and beam system).  I'll help if I can.
Cheers.
**Using Revit Architecture 2009, 2011, and 2012**
Sun, Jan 27, 2008 at 8:48:47 PM | Structural beam system visibilty
sgeelen
Thanks for the reply.
If you open the attached file (Revit Arch 200Shadey and go to the Lower Floor plan.
You will see the beams in the beam system for the roof rafters show even though beam systems are turned off and the view range is lower than the beam level.
 I still want to show beams in this view as certain in wall beams will need to bew visible.
 Cheers for your help
 Stefan
Mon, Jan 28, 2008 at 8:07:05 AM | Structural beam system visibilty
LIZARD2806
3.5 Stars: 7 Votes
nothing attached...
Mon, Jan 28, 2008 at 2:11:09 PM | Structural beam system visibilty
sgeelen
This time with the attachement
Mon, Jan 28, 2008 at 2:33:17 PM | Structural beam system visibilty
NKramer
4 Stars: 9 Votes
You can only post 2mb files. Which isnt much for Revit. You really have to clean up the file (purge out all unudes families, sheets, etc) in order to get a project down to that size. Otherwise you can try posting individual families, screen shots, etc. AUGI will allow a 5 mb file but other than that you would have to do email or .ftp.
Nick
Mon, Jan 28, 2008 at 5:52:51 PM | Structural beam system visibilty
sgeelen
The file I tried to upload earlier was under 1Mb so don't know what the problem is.
Anyhow - I've attached a smaller one.
Cheers
Mon, Jan 28, 2008 at 6:08:26 PM | Structural beam system visibilty
NKramer
4 Stars: 9 Votes
Still not getting anything attached. I belive that you need to wait for the file to show up in the blue box prior to posting your reply, otherwise it gets lost on the upload. This may take a while if you are using cable, dial up etc.
Nick
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:43 PM
structural beam system visibility
Fri, Jun 27, 2008 at 12:24:51 PM
structural beam system irregularity
Fri, Dec 19, 2008 at 3:03:10 PM
sloping structural beam system - having difficulty in drawing
Thu, Dec 30, 2021 at 10:33:02 AM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:10 PM
Page generation time: 1.4999
