48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Partial Ceiling Grid Demolition HELP!!!
Wed, Dec 5, 2007 at 10:34:36 AM | Partial Ceiling Grid Demolition HELP!!!
mflure
Greetings all,
I think this subject has come up once before, but I cannot find it or figure a way around this.
I have two adjacent ceiling grids and I need to demolish a small portion of one and extend the other in its place but I cannot for the life of me figure a way to do that and still make it look correct graphically.  I can create multiple grid systems and demolish the segments but the problem is the boarder of the ceiling grid make everthing look wrong.  Does anyone know of a fancy trick to do this??
Michael Flure
Wed, Dec 5, 2007 at 12:37:06 PM | Partial Ceiling Grid Demolition HELP!!!
LIZARD2806
3.5 Stars: 7 Votes
create multiple grid systems...the lines shouldn't get in the way, as chances are the grid will be demolished on a grid line (not in the middle of a ceiling tile).  Example-make the existing grid (let's assume it's square).  Get the grid aligned as existing.  Then draw the ceiling being demolished (yes, you are drawing a second "existing" ceiling on top of the first).  Align the grid appropriately.  Then modify the first grid so that it no longer has the demo portion as part of it.  Then demo the second ceiling and add your new one.  If for some reason you do happen to have lines you don;t want to see, use the linework tool and change the lines to "<invisible lines>"
Fri, Feb 1, 2008 at 11:47:45 AM | Partial Ceiling Grid Demolition HELP!!!
mflure
Thanks that worked..
Mike
Light fittings in ceiling grid
Tue, Feb 8, 2005 at 6:33:50 PM
Ceiling Grid
Wed, Mar 16, 2011 at 3:15:51 PM
rendering ceiling grid
Wed, May 16, 2007 at 1:37:32 PM
Grid Partial Visibility
Wed, Aug 3, 2016 at 1:08:40 PM
Can we create our own ceiling grid?
Mon, Jul 11, 2011 at 8:35:02 AM
Page generation time: 2.0278
