47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Show Symbol in all plan views?
Tue, Dec 4, 2007 at 1:42:16 PM | Show Symbol in all plan views?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is it possible to have the same symbol show up in all my plan views?  I am wanting my North arrow to be in all views inthe same spot.  So if I move it on floor two...it moves in floor one.  Thanks,
Lorne
Denver, CO
Revit Architecture
Tue, Dec 4, 2007 at 3:20:47 PM | Show Symbol in all plan views?
LIZARD2806
3.5 Stars: 7 Votes
Draw two reference planes (x and y) on the lowest level.  Insert the North arrow and lock it to the reference planes in both the x and y directions.  Insert the North arrow on all subsequent levels, locking them to the same reference planes as well.  When you want to move the North arrow, move the reference planes, not the North arrow (Revit won't let you move the North arrow anyway, as it is constrained).  Since all the north arrows are constrained to the two reference planes, all of the North arrows will move when the reference planes are moved in any view.  HTH.
Cheers.
**Using Revit Architecture 2009, 2011, and 2012**
Tue, Dec 4, 2007 at 3:38:54 PM | Show Symbol in all plan views?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
THANKS
Denver, CO
Revit Architecture
Tue, Dec 4, 2007 at 4:31:44 PM | Show Symbol in all plan views?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Ok just kidding that didn't work...I don't get what I'm doing wrong.  I drew two Ref Planes on our bottom level.  Then locked the symbol on both axis'.  Then went to our second floor...and no dice.  Nothing there.  I went to the view properties and set the bottom of the view plane to unlimited.  Still nothing but the ref planes.
Denver, CO
Revit Architecture
Tue, Dec 4, 2007 at 4:45:02 PM | Show Symbol in all plan views?
LIZARD2806
3.5 Stars: 7 Votes
you need to add the symbol to every level and lock it to the ref plane at every level.  The annotations only will show up in the view they are drawn (they are not model objects), the ref planes just enable you to lock annotations together so when you move one, they all move.  If you wanted to do this with view depths and or plan regions, you would need to make your north arrow out of model lines, but there are some inherent problems with that strategy, so I would just keep it with a symbol at each level locked to those two reference planes.
Cheers.
Tue, Dec 4, 2007 at 4:50:42 PM | Show Symbol in all plan views?
Your north arrow is only a 2d element - you have to insert it in every view where you want it.  If you just copy it to clipboard from your first level, you can then paste it same place in each plan and lock it to the reference planes as described.
We don't put our symbols on the plan.  Instead, we put it on the sheet with the title.  Seems to make more sense there.
Tue, Dec 4, 2007 at 5:02:15 PM | Show Symbol in all plan views?
LIZARD2806
3.5 Stars: 7 Votes
We, too have the North arrow in our titleblock.  We then added a yes/no parameter to control the view (don;t want a North arrow on the elevation sheets) and then we also added a project parameter for the angle of North, so that the angle can be controlled on all sheets.  It really depends on your office standards as to what makes the most sense for you.
Tue, Dec 4, 2007 at 5:41:41 PM | Show Symbol in all plan views?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Great thanks for the help.
Denver, CO
Revit Architecture
2D nested annotation symbol doesn't show when family is sloped in 3D
Tue, Aug 2, 2011 at 2:58:56 PM
Symbol lines in both ceiling and floor plans
Fri, Nov 6, 2009 at 1:01:55 PM
Plan Range - displayingn duplicated views
Wed, Aug 1, 2007 at 8:45:02 AM
Family w/2D Symbol - Toggle On/Off
Mon, Mar 9, 2015 at 8:54:44 AM
section line continuity between floor plan views
Thu, Aug 31, 2006 at 4:54:20 PM
Page generation time: 1.5855
