32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> A bug or a program setting?
22 Posts No Rating |
I can't seem to move my doors and other items.
After I have placed a door in a wall, I click the temporary dimension and type in a new number but the door doesn't move after I hit enter.
Also when I dimension the door to two walls and click the "EQ", all I get is a popup saying "Constraints not satisfied."
But if a click and drag the door it will move in the wall.
This problem seems to happen with toilets as well. Any ideas?
I GET THE SAME THING WITH WINDOWS. WHAT I FLOUND THAT CAUSES IT IS WHAT ITEM I AM CHOSING TO MOVE. EITHER THE WINDOW DIM OR THE WINDOW ITSELF. PLAY AROUND WITH THE PARTICULAR ITEM YOU GRAB. I THINK YOU WILL NOTICE A PATTERN TO YOU PROBLEMS AND YOU WILL UNDERSTAND HOW NOT TO DO IT THE NEXT TIME. MYSELF IT SEEMS LIKE I ALWAYS FORGET AND END HAVING TO FIGURE IT OUT FOR THE FIRST TIME ALL OVER AGAIN.
----------------------------------- PWD |
REVIT 2011 BUG OR NOT BUG? |
Mon, Dec 6, 2010 at 6:28:30 PM
Ramps unaffected by cutplane setting? |
Wed, Oct 8, 2008 at 10:39:56 AM
Revit 08 Dual Montor program hang |
Wed, Apr 9, 2008 at 9:20:19 AM
v.9 area analysis |
Fri, Apr 21, 2006 at 6:23:33 PM
Combining Elevation Tags? |
Tue, Jun 1, 2010 at 11:25:56 AM
Members: | 2019236 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
