38 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> creating/modifying a pylon to host an opening with large trim
Mon, Dec 3, 2007 at 2:58:25 PM | creating/modifying a pylon to host an opening with large trim
K8vitali
i am in the process of creating a prototype retail store for the firm i am working for. one of the elements we need to create is a gateway pylon that is 45' long, by 4' deep with a centered opening measureing 27' wide by 16'8" high. the issue i am having is that i cannot trim out the opening-  i have a profiles created for it, but it will not apply correctly. all it will do is wrap the wall.    i have tried to modify the cased opening family to work with these parametrs, but so far i am unsuccessful.  i was wondering if it might be easier to create a new family and adjustable component for this pylon seeing that it is prototypical and most likely will not need editing... anyone have any ideas? i attached a photo of the pylon for clarity
thank you for any insight!!
Mon, Dec 3, 2007 at 3:17:49 PM | creating/modifying a pylon to host an opening with large trim
IDN101
2.5 Stars: 3 Votes
Extrusions and sweeps- job done in 20 minutes!
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Mon, Dec 3, 2007 at 3:35:03 PM | creating/modifying a pylon to host an opening with large trim
K8vitali
i have tried that, but i will try again before i state for sure that it does not work.  thanks a bunch- i will reply as soon as i have figured this out to keep the status fresh on my post-
Stone trim at top of arched opening
Mon, Aug 21, 2006 at 5:16:38 PM
Door Trim Parameters
Fri, Sep 11, 2009 at 12:52:57 AM
Modifying Openings in Floors
Sun, Jun 7, 2009 at 1:59:28 AM
Tricky Window Trim
Thu, Mar 9, 2006 at 1:14:00 PM
How can you get lines to trim with opening cut in double tee?
Mon, Nov 10, 2008 at 11:40:30 AM
Page generation time: 0.7891
