53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Join geometry - Structural column with wall
Sat, Dec 1, 2007 at 7:56:15 PM | Join geometry - Structural column with wall
Miguell
Usually, a structural column is more important than a wall but I think Revit decided I was wrong! When I make join geometry, select the column and the wall, the column changes to the wall color. I don't have this problem usually, it is only in some views.
www.jeanpierrebart.com
Montréal, Québec
Column Join issue
Wed, Oct 11, 2017 at 10:10:15 PM
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
Parallel walls join geometry do not cut opening
Fri, Jan 31, 2020 at 1:32:48 PM
Revit Structure 2008 SP2: Join Geometry on differnet beam families
Wed, Sep 19, 2007 at 11:58:38 AM
Custom wall shape around structural column
Sat, May 26, 2018 at 6:26:57 AM
Page generation time: 0.8934
