Forums >> Revit Building >> Technical Support >> Can you make wall joins Miter by Default?
Fri, Nov 30, 2007 at 3:24:22 PM | Can you make wall joins Miter by Default?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is there a way to make wall joins Miter by Default?  I mean while building walls they are mitering.  Rather than having to go to Edit wall joins afterwards adn switch them all from Butt Joins to Miter Joins?
I am trying to put Corner Trim on our building and they will not go all the way to the edge if the walls are not mitred.
 Second about the Corner Trim.  Can I mitre those once the Vertical Wall sweep is placed?  Thanks,
Lorne
Denver, CO
Revit Architecture
Tue, Dec 4, 2007 at 11:17:35 AM | Can you make wall joins Miter by Default?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Can anybody help me with this?
Denver, CO
Revit Architecture
Thu, Dec 13, 2007 at 3:09:42 PM | Can you make wall joins Miter by Default?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
really need to know if this is possible or not.  Anybody?  Just tell me yes or no.  thanks
Denver, CO
Revit Architecture
Thu, Dec 13, 2007 at 3:44:28 PM | Can you make wall joins Miter by Default?
johnpaulrogers
As far as I know you can't, but I'm not certain.
jip
Sat, Dec 15, 2007 at 2:44:45 PM | Can you make wall joins Miter by Default?
Oktober
it would be nice to have this as a default, lets hope it is addressed in 2009 version
Fri, Aug 13, 2010 at 4:16:19 PM | Can you make wall joins Miter by Default?
critter
Any response on this issue?
Tue, May 20, 2014 at 7:08:56 AM | Can you make wall joins Miter by Default?
DuncanNZ
DuncanNZ Avatar
Now Revit 2015 is out and ... still no change on this issue
Tue, May 20, 2014 at 9:47:58 AM | Can you make wall joins Miter by Default?
mansell5
3.5 Stars: 4 Votes
i guess the developers were trying to cover the majority of wall junction types.
ie 2 dissimilar walls , say a brick wall intersecting a timber stud wall at a corner.
that type of junction would not be mitred, but butt jointed etc.
Tue, May 20, 2014 at 9:59:23 AM | Can you make wall joins Miter by Default?
I agree with mansell, I rarely have to use the miter junction because the default works on 99% of all of our walls.
Tue, May 20, 2014 at 10:42:05 AM | Can you make wall joins Miter by Default?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Yea since I've posted this post...7 years ago!!  I havent' needed to use this all that much.  The main reason I want the walls to be mitered is merely the export to sketchup.  If they are but jointed there is always a line on the corners of walls in sketchup that is just annoying ot delete at EVERY corner.
Other than that you're right, typical construction is not mitered...maybe on precast walls if that's the corner detail.  But even then the mitre on a precast corner isn't that nice usually!
Thanks,
Lorne
Denver, CO
Revit Architecture
Tue, May 20, 2014 at 6:51:09 PM | Can you make wall joins Miter by Default?
mansell5
3.5 Stars: 4 Votes
you have me slightly intrigued mate, why export to sketchup?
what can sketch up do that revit cant?
Wed, May 21, 2014 at 8:02:12 AM | Can you make wall joins Miter by Default?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Well for starters the walkthrus are way easier to create and export.  They look a tad better and we can put in our people families, consoles, paint colors, etc.  Just a time saving opportunity.
In addition to that we us Lumion.  Lumion and Sketchup work better than Lumion and Revit.  We can edit materials, etc in Sketchup, and bring into Lumion as well as edit those materials in Lumion too.
Make sense? We have been using Revit since 2005 and we are very profisient at it, however we find Sketchup/Lumion combo to make much better models/animations/renderings than Revit.
Check out our Lumion model here: http://www.youtube.com/watch?v=UKfD6dzdgv8&feature=youtu.be  You can see the still renderings from Lumion (each still took about 5 mins to export not 50 hours like Revit!): http://www.slarc.com/portfolio-view/coastal-wharf-control-building/
Denver, CO
Revit Architecture
Wed, May 21, 2014 at 8:17:17 AM | Can you make wall joins Miter by Default?
#13
mansell5
3.5 Stars: 4 Votes
wow  good   great  stuff  there.
lumion videos ive seen on youtube do look great.
is it hard to learn? (ie harder than the revit learning curve).
maybe sketchup / lumion is the future.
cheers
geoff
Wed, May 21, 2014 at 10:22:43 AM | Can you make wall joins Miter by Default?
#14
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Actually it's pretty easy to learn.  You can't build much in it other than objects.  Hence why we use it with sketchup.  However our building is done in Revit as that's what we use for working drawings.  Sketchup/Lumion is what we use for presentation tools.
As far as the learning curve, the interface and keys are the hardest.  Once you figure out how to move (not like any other program I've used) it's easy.
Denver, CO
Revit Architecture
Wed, Dec 21, 2016 at 1:52:44 PM | Can you make wall joins Miter by Default?
#15
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Just to revisit the corner mitre problem in REVIT 2016 (at least) in a PLAN view, you can use a window to select multiple intersections all at once. Then select mitre, then click out to complete it. It's not exactly intuitive and there's probably alot of people who still do them one at a time lol but there you have it !
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
wall miter
Thu, Jul 24, 2008 at 1:35:12 PM
Changing Default Wall Joins Revit 2011
Fri, Aug 13, 2010 at 4:14:12 PM
wrap exterior face of wall at ends as an instance not a type parameter
Thu, Mar 27, 2008 at 9:22:30 AM
Revit 2014 - Disallow wall joins by default
Tue, Jun 17, 2014 at 10:23:21 AM
Page generation time: 2.6889
