58 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> DEMENSION TO POINTS
Fri, Nov 30, 2007 at 9:27:03 AM | DEMENSION TO POINTS
Andrea1983
Is there a way to dimension to a midpoint of a line?  I have a few items that need to be drawn as model lines, just to show there approx location, but I just want to place their center.
Fri, Nov 30, 2007 at 1:03:57 PM | DEMENSION TO POINTS
aandr001
4.5 Stars: 6 Votes
You can dimension to the intersection of 2 lines.  So make the model lines intersect at their center and add your dimension.
Topographic points
Thu, Nov 27, 2008 at 9:22:44 PM
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Exporting topography points from Revit to AutoCad
Sat, May 23, 2015 at 11:21:41 AM
Selecting Topographic Points based on Elevation
Tue, Aug 7, 2012 at 3:16:32 PM
dwg elevated points can't create topo in Revit
Fri, Nov 8, 2013 at 1:06:31 PM
Page generation time: 0.2958
