31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Taper Insulation sloping flat roofs
Wed, Nov 28, 2007 at 3:56:58 PM | Taper Insulation sloping flat roofs
trhymans
I have been playing w/ the shape editing for slabs and roof.  The help screen talks about sloping roofs on the top surface and leaving the bottom the same as would be used w/ tapered insulation on a flat structure.  I have used the draw points tool and the split lines tool to get the top surface the way I want it but I can't seam to get the material to have a level bottom surface.  I get the right top surface but the material remains a constant thickness so it is no longer on the deck or structure.  Anyone have any ideas on a setting that allows the material to vary in thickness while keeping a level bottom and sloping top?????  I did try attacing the roof system to the joist supports and then using the points tool to get the top surface correct but it still remained a constant thickness and pulled the insulation away from the structure.  HELP!!!
Wed, Nov 28, 2007 at 4:12:20 PM | Taper Insulation sloping flat roofs
coreed
coreed Avatar
4 Stars: 16 Votes
watch this tutorial, it's for Revit Structure, but it works for Revit Architure also.
http://www.avat.com/training/elearning/media/techtips/index.asp?mid='289'
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Nov 28, 2007 at 5:22:09 PM | Taper Insulation sloping flat roofs
trhymans
Thanks
 I had just found the variable layer item in the floor and roof dialog but the video make all the other features much easier to understand.
The roof tapering tools need to be available on sloped roofs.
Wed, Aug 19, 2009 at 10:33:18 AM
create-parts and multi-layered roofs with shape edits
Sun, Feb 21, 2016 at 9:27:04 AM
Vallys in flat roofs?
Wed, Aug 2, 2006 at 2:37:27 PM
flat roofs
Wed, Feb 1, 2006 at 3:15:52 PM
New Member-flat/sloped roof problems.
Thu, Jul 9, 2009 at 2:43:41 AM
Page generation time: 0.4366
