Hi all, I exported about 65 high res 3337x1592) jpegs out of a 300 frame animation, from a walkthrough (becuase it took so long to render and export. I recieved great image quality but when I use WMM (Windows Movie Maker) they are blurry. I'm not gona use that to make an animation from jpegs anymore. Virtual Dub is tricky to download for me. The mirror sites are not working for some reason. Now, I noticed that when I export a wireframe walkthrough at the same resolution as an AVI, the image quality is great. But I also used the cinpax compressor when seems to be built into revit. That compressor I choose when exporting. So using a wireframe export (with this compressor) at a high resolution seems to work great... If I decide to export a rendered walkthrough at 3337x1592 (high res.) it will take too long to render (all weekend even maybe). But that seems to be the only option in order to make a great looking video. My question to you all is, is exporting the jpegs or the avi in 100% 3337x1592 with that particular compressor, and choosing the avi option and not the jpeg option, the only way to achevie the highest quality animation in Revit? I mean there might be a way that the compressor I used will make the rendering animation file size small enough to play, but I wouldn't count on it. Thank you all-
