67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Change CMU line type globally
Wed, Nov 28, 2007 at 12:38:21 PM | Change CMU line type globally
Blakejl
Does anyone know how to change the line type for CMU in plan view, globally? I'm not referring to the hatch pattern, but the edge line type. I want to change it from a solid line to a dash dot pattern.
Wed, Nov 28, 2007 at 1:49:57 PM | Change CMU line type globally
aandr001
4.5 Stars: 6 Votes
Are you referring to a CMU wall or a detail component?
Wed, Nov 28, 2007 at 1:59:40 PM | Change CMU line type globally
Blakejl
I am referring to the wall, not a component.
I am able to select each wall and change the cut line type by overriding the graphics in each view, but we want them to always show up this way.
Wed, Nov 28, 2007 at 3:30:40 PM | Change CMU line type globally
aandr001
4.5 Stars: 6 Votes
Well, this is a work around, but you could change all the CMU walls to a different phase and then assign all the walls in that phase to appear as dash dot? Unfortunately, in object styles, you can only change the look of all the walls not just the CMU ones.
Wed, Nov 28, 2007 at 5:35:53 PM | Change CMU line type globally
Blakejl
Thanks for your imput. I had done that before on another project, but figured there must be a better way.
Thu, Mar 13, 2008 at 6:18:05 PM | Change CMU line type globally
DomC
Make the change to your templete. Then make sure when you start a new job to use that templete. All CMU walls then should be global with that file.
Hello Newbie here, brick on brick on cmu wall type doesn't show up
Thu, Jan 27, 2011 at 1:06:16 PM
globally changing text font
Wed, Apr 30, 2008 at 8:50:37 AM
Line Type Weight Will Not Change, Overrides Set Will Not Show [ 1 2 ]
Sun, Dec 13, 2020 at 11:51:33 AM
17
How to change a file from Imperial to Metric
Sun, Feb 17, 2013 at 9:20:20 AM
CMU Wall
Thu, May 7, 2015 at 12:15:48 PM
Page generation time: 0.9676
