56 Users Online (55 Members):
Forums >> Revit Systems >> Technical Support >> Accursed plumbing fixture display
![3 Stars: 2 Votes](/images/stars_3.gif) |
I've tried to find a similar thread to this problem but to no avail so I'll pose it myself. Why is it that plumbing fixtures display differently to generic models? For instance I have two downpipes exactly the same, but one is a generic model which displays in all views as it should, and one is a plumbing fixture which refuses to be cut by any view and instead displays the model in its completeness (see level 1 & level 2 pics attached section dwg diplays how the two DPs look.) This is a problem that seems to recure throughout all revit versions i've used. Anybody got any ideas about how to get rid of this (very annoying) issue?
![4.5 Stars: 6 Votes](/images/stars_4.5.gif) |
This probably has to do with the family itself. I think if you compare the visibility settings between the plumbing fixture and the generic model there may be a difference. The other culprit may be that one extrusion is able to be cut while the other is not, also a "family" issue. In your help menu look up cuttable families and (under"Family Editor Commands" using symbolic lines.
I should probbably have put this thread under revit building but what ev... aandr001 thanks, yeah that seems to be it. Nothing to be done by the looks of it. Seems bloody stupid to me tho...especially if you have downpipes doing crazy things...
Plumbing Fixtuer Tags |
Wed, Feb 4, 2015 at 1:41:00 PM
Plumbing fixture and snapping to corner |
Fri, Apr 4, 2008 at 2:46:40 AM
Light fixture not appearing in fixture schedule |
Thu, May 7, 2015 at 7:26:00 AM
create a plumbing fixture count schedule |
Tue, Apr 10, 2018 at 1:08:32 AM
How create a face hosted "Plumbing Fixture" family? |
Wed, Sep 21, 2016 at 1:55:44 AM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
