52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> I can't insert a window family that I created.
Mon, Nov 26, 2007 at 11:21:55 AM | I can't insert a window family that I created.
donkey
I have created a window family called "Window_Office_EW_A" and it will not insert into a wall in my project. I get the following notices in the warning pop up window:
Error - Can't make type "Window_Office_EW_A".
Warning - None of the created elements are visible in Floor Plan: Level 2 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
Any thoughts on how I might resolve this?
Mon, Nov 26, 2007 at 1:24:54 PM | I can't insert a window family that I created.
IDN101
2.5 Stars: 3 Votes
Quite likely that the wall you are trying to insert the window into is not wide enough to accept the family.
How thick is the wall? Edit the family you created and make the sample piece of wall more narrow- adjust any constraints / parameters accordingly. Reload into project.
Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Suddenly can't insert window in project............
Wed, Aug 3, 2016 at 11:36:50 AM
13
downloaded the window AC but can't insert it
Mon, Oct 2, 2006 at 9:29:34 AM
Window family doesn't cut properly in plan
Wed, Aug 5, 2015 at 6:44:07 AM
Window's dimension don't show up in the window schedule
Fri, Aug 17, 2012 at 1:34:43 PM
Daylight Family
Sat, Aug 27, 2005 at 8:44:08 AM
Page generation time: 1.1424
