70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Handrail with glass panel problem
Fri, Nov 23, 2007 at 2:15:32 PM | Handrail with glass panel problem
Miguell
I created a handrail and I was wondering if there is a way to make an "ajustable panel" that would cut at the corner to avoid that result.
www.jeanpierrebart.com
Montréal, Québec
Mon, Mar 3, 2008 at 4:22:53 PM | Handrail with glass panel problem
webb
webb Avatar
bump for this__
I'm dealing with the same problem and haven't found any solutions posted in the threads yet.  any help would be appreciated, especially when taken in context with stairs.
thanks.
Mon, Mar 3, 2008 at 4:36:35 PM | Handrail with glass panel problem
Try doing your glass panels as a rail.
Mon, Mar 3, 2008 at 5:49:44 PM | Handrail with glass panel problem
webb
webb Avatar
thanks.
that works for a work around, but any ideas if I need a panelized, articulated system?
where I'm running into trouble is with having a panel that can follow the slope of the stair.  what I'm shooting for is something like this, but I keep getting panels that maintain 90 degree angles.
Tue, Mar 4, 2008 at 12:37:24 PM | Handrail with glass panel problem
As I said - rails..... check out this tutorial
http://revit-alize.blogspot.com/2005/11/stairway-to-heaven.html
Tue, Mar 4, 2008 at 5:51:49 PM | Handrail with glass panel problem
webb
webb Avatar
thanks for all of the help- but unless there is a way to interupt rails, this solution isn't what I'm after.
 the solution in the tutorial creates a swept plane of glass that starts at the top of the stair and ends at the bottom.  if I was interested in creating a system that is created of panels that are interrupted through out the stair, then this wouldn't be the solution.
in the photo I posted, there's an interuption to the sweep halfway down the stairs (2 panels).  any ideas on how I could do this with out the result miguell found?
Glass Balustrade with side mounted handrail
Mon, Nov 18, 2013 at 11:31:01 PM
Glass Handrail
Thu, Jan 29, 2009 at 4:32:06 PM
Glass handrail
Wed, Aug 8, 2012 at 10:44:13 AM
Glass balustrade handrail
Wed, Oct 12, 2016 at 3:28:15 PM
Problem selecting glass using tab key
Thu, Mar 21, 2019 at 1:17:38 PM
Page generation time: 0.8472
