45 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> EDITTING FILL PATTERNS
50 Posts No Rating |
after using a particular fill pattern in a wall i find that the pattern is not dense enough and would like to edit it . how do i do that from an exisiting fill pattern without having to import one from elsewhere.
thanks for your responses
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
I'm assuming you are talking about custom patterns as simple patterns can be easily changed.
When importing any pattern you can change the scale once imported by using the scale control at the bottom of the pattern settings window...
But yes you must import it first then fiddle with the scale afterwards.
HTH.
thanks mr spot
let me see if i can clarify this further: when i go to fill patterns and apply say concrete to a wall i find out that the pattern does not show densely enough in the drawing so what i was hoping i could do is to select the fill pattern in the list click edit and in the modify properties box enter in a new name and change the scale .the options are grayed out in the box so is there anyone around this? and yes it has to be custom i suppose
thanks
Not there is no such dialog box for already imported pat files. In this case (for concrete), you would need to choose import then navigate to your revit.pat file, select concrete then select the appropriate scale...
This is the only time you can scale a fill pattern.
HTH.
ok thanks mate
17 Posts No Rating |
Similar issues and I see that Chris has quite a bit of knowledge on this topic. Hope you don't mind my tagging on.
I haven't been able to scale a pattern on import. The scale box remains grayed out. Any idea why?
Click in the name box after you select the import pattern. The scale box will then become active.
5 Posts No Rating |
I had a similar question. I am trying to create an exterior look of vertical 1x4 Battens @ 20" O.C . I haven't seen any pattern similar here at revitcity. I can only create a single line with a Simple pattern. Can I create my my own custom pattern? Any help would be greatly appreciated.
44 Posts No Rating |
How is this?
http://www.revitcity.com/patterns.php?action=view&pattern_id=204
Sam Spencer
Perpsective Fill Patterns |
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns |
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns |
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they? |
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question |
Tue, Oct 23, 2012 at 8:39:37 AM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
