60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> How to use Multiple Monitors with Revit
Tue, Nov 20, 2007 at 9:12:59 PM | How to use Multiple Monitors with Revit
kprossick
 1) What you need to do is set the desktop to extend across all of your monitors you are using.
2) Start Revit Architecture. It will either appear in a single monitor or across all of the monitors combined.
3)  Make sure that Revit is set to be in a floating window (one that is not locked in place but can be moved).
4) Move the Revit Window so the top left corner of the window aligns with the top left corner of your furthest left monitor (top left monitor if you stack monitors vertically)
5) Drag the bottom right corner of the Revit window to align with the bottom right corner of your bottom-right most monitor.
6) When you open up views within a project, make them flowating windows, and you can move them around in any way you wish across all the monitors now.
7) The only drawback is that when you finish the session, I have not found a way to keep the settings exact. However, I have found that if you open Revit through the Project File you want to work in and NOT the Revit Icon on the Desktop, all you have to do is simply align the corners. Revit will remember the locations of the views within the Revit Window, so Once you align the corners you should be good to go.
For example. I currently use 3 Monitors. The Center is my main with 2 flanking monitors on either side. With Revit extended over all the monitors I use the left monitor for 3d Views of my model and schedules, the center monitor I use for the floor plans, and the right monitor for elevations and sections (as well as using it a sthe monitor that my Web Browser is set to open (like when I access Revit City and Autodesks Revit Web Library to download Families)
The only drawback is that the Design Bar and Menu Bar are on the far left side. The Project Browser can be moved however to where ever you want it. There might be a way to move the Design Bar, but it doesn't bother me where it is, so I haven't looked into it. The good part about Revit is there is more than 1 way to get to a command (ie Right Cliking) and if you take the time to conform to them, then this becomes a minor issue. Also, for me, with the Design Bar and Project Browser on the Far Left, I have the full width of the center monitor for the Floor Plan Views where I do most of my work.
Unfortunately, it is not an automatic thing and takes time to learn how to set-up, but once you do, it works beautifully.
I do wish that revit could remember to open up extended across the monitors, but hey, that's what wish lists are for. In the end, the 30 Seconds it takes to open Revit and realign the windows is miniscule compared to the amount of time I save by doing it.
Good Luck.
Shine On You Crazy Diamonds,
Keith Prossick
Wed, Nov 21, 2007 at 4:45:32 AM | How to use Multiple Monitors with Revit
OktoberFire
OktoberFire Avatar
excellent, great post Smile
gonna make working in revit a lot easier as i run dual monitors.
Thu, Feb 14, 2008 at 11:12:31 PM | How to use Multiple Monitors with Revit
aspect
Like a lot of the interface things about Revit - this limited part of its functionality needs some work. (Take a look at Adobe stuff - use of toolbar tear-offs, etc for ideas on what to do). All toolbars including the design bar should be able to be positioned where ever you want on whichever screen you want (if you use multiple screens like a huge number of people do these days). Autodesk should look a bit past the end of their short, money-hungry noses and cater for all sorts of people (left handers, right handers, single/multi screen, etc, etc). Lets face it, with the cost of the software, basic user interface stuff like this should be a given.
www.aspectarch.com
Multiple monitors
Tue, Nov 20, 2007 at 8:53:21 PM
Two monitors
Wed, Apr 26, 2006 at 11:08:36 PM
two monitors?
Wed, May 3, 2006 at 7:30:53 PM
Floating Windows 4 Multiple Monitors & wow putting CAD into sweeps is work.
Fri, Jul 14, 2006 at 4:58:12 PM
Multiple Displays
Thu, Jul 21, 2005 at 11:50:41 PM
Page generation time: 2.0381
