66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> split segment on detail view
79 Posts No Rating |
Anybody have the problem when using split segment, when you do it and pull the detail bubble off to the side to where you want it, you click the 2nd point you want it moved to and it will automatically jump a couple inches up or over on the sheet and make the leader to the actual cut way too long? I dont see any apparent reason for this and it seems like it is a glitch. It adds quite a bit of uneccessary mess. I hope there is an answer to this.
----------------------------------- HuntFlo |
oh yeah, I'm using Revit '08.
split segment on interior elevation view callout? |
Tue, Sep 13, 2011 at 3:32:40 PM
Using spit segment when cutting a detail on plan |
Wed, May 10, 2006 at 9:17:10 AM
SPLIT A SEGMENT OF A SECTION |
Wed, Nov 8, 2023 at 12:46:54 PM
split segment on elevation |
Wed, Feb 12, 2014 at 8:55:30 PM
Making a Clean Split |
Sun, Jul 11, 2010 at 1:51:14 PM
Members: | 2016928 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
