35 Users Online (33 Members):
Forums >> Revit Building >> Technical Support >> FAMILY EDIT - adding hidden lines to casework to show shelves in elevation
Ok, I've been messing with this one for awhile now. I am trying to add hidden symbolic lines to my cabinets to resemble shelves inside the casework. I have set up reference planes to lock to the sides of the cabinet. Then I set up my symbolic lines and locked the ends to the Ref planes. Then I use Array and specify how many I want to add. I lock the top symbolic line to the bottom of the cabinet (just to hide it) and same with the top line. Then in the parameters I have one titled: "Number of Shelves" (instance integer), and another one titled "##" (instance integer). The ## is the number of symbolic lines including the two that are locked to the top and bottom. The other one is set to = ## - 2. This gives the user the ability to type the number of shelves in without needing to worry about the two hidden lines. This works great and I can add 100 shelves or 3 and it adjusts when the Height is changed. But when I change the width, the shelves don't follow. I can't figure out why. Because the reference planes are locked to the width. Before I array my lines and they becomed grouped items, I can change the width and it works fine. But without the grouped array I can't use the integer parameter to allow users to change the number of shelves. So does anyone know what I am doing wrong? I have tried all ideas from crontroling the shelf width (which doesn't work either) to playing with the interger parameters. Please help! Thanks in advance, Lorne
Denver, CO
Revit Architecture |
Here's the file if my description wasn't confusing enough
Denver, CO
Anybody please?
Denver, CO
I need to resurface this...still haven't figure out how to accomplish this. I just basically need to know how to Array lines as a group and set a family parameter to edit the number of lines it shows. Then lock the ends of the lines to an object. If the object changes width the lines follow. I can't get it to work. Thanks. Lorne
Denver, CO
Try this one, Create a family containing only one symbolic line, with width parameter. And nested it to your main family, and link the component width with the main family width, I attached my small experiment, and it looks correct. Best regards, Arthur Gunawan
Edited on: Tue, Feb 12, 2008 at 3:24:51 AM
Revit Architecture 2011 |
Revit Family Casework looks different from 3d view to elevation |
Mon, Nov 13, 2017 at 4:38:23 PM
shower enclosure & casework visiblity |
Sun, Nov 5, 2006 at 12:53:09 PM
Hidden lines in elevations |
Mon, Sep 10, 2007 at 9:43:06 AM
Casework below in-place component won't show - R09 |
Fri, Dec 4, 2009 at 11:50:12 AM
Elevation/Creating Hidden lines |
Fri, Mar 12, 2010 at 12:43:17 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
