88 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> line style in plan view
Mon, Jan 5, 2004 at 10:29:22 AM | line style in plan view
Bimman
Bimman Avatar
1 Stars: 2 Votes
when inserting a steel beam it comes in as a solid line in plan view. what is the process in which you change it to show up as a center line or dashed line.
PWD
Mon, Jan 5, 2004 at 10:32:08 AM | RE: line style in plan view
Bimman
Bimman Avatar
1 Stars: 2 Votes
this would also be used to dash my footer lines.
Mon, Jan 5, 2004 at 11:32:18 AM | RE: line style in plan view
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
have you tried using the linework tool? It basically allows you to change the linetype of objects...
Hiroshi Jacobs
Mon, Jan 5, 2004 at 11:33:42 AM | RE: line style in plan view
Bimman
Bimman Avatar
1 Stars: 2 Votes
no i have not ried that tool i'll give it a try and let you know. thanks
PWD
Mon, Jan 5, 2004 at 12:08:50 PM | RE: line style in plan view
Bimman
Bimman Avatar
1 Stars: 2 Votes
that was it. thaks again
PWD
Mon, Jan 5, 2004 at 12:51:23 PM | RE: line style in plan view
Bimman
Bimman Avatar
1 Stars: 2 Votes
let me ask this, rather than having to pick each line that i need to change for my footer. could i make the footer so when it is inserted that when in plan view it shows up already dashed. i know when you are making certain families you can set the amount of detail you see when in a particular view. but where do you edit the detail view of the wall. i know where to change and add structure to the wall but not detail. all this in order to save time from havong to go back over the footer lines. do you think it could work.
PWD
Mon, Jan 5, 2004 at 3:12:51 PM | RE: line style in plan view
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
yes, you can do this using object styles. Basically you open up the footer family, assign object styles or subcategories to each family solid and then assign a linetype to that subcategory. When you import it to the project it should show that linetype as long as your object style subcategories in the project match up. Confused yet?? It's pretty simple once you get the hang of it but a little hard to explain... It's pretty involved so I suggest you look it up in the help menu. Open up your help and click the index tab. Type "object styles" in the keyword box and select "object styles command" hope that helps!
Hiroshi Jacobs
Thu, Mar 4, 2004 at 12:47:43 PM | RE: line style in plan view foundation walls and footers
FMCustomDesign
Here is another way, if you use a sweep to create your footer in a foundation wall type, it works nicly, can you change that wall type to have dashed lines in elevation? As well as in plan?
Visual Style of Beams in Plan View
Thu, May 22, 2014 at 4:01:03 PM
Line Style is acting up, showing wrong line property
Sun, Aug 21, 2016 at 11:07:44 AM
Cant see site features in First Floor Plan
Thu, Jan 31, 2008 at 7:10:59 AM
Object not visible in plan view, Revit 2014
Fri, May 23, 2014 at 10:29:37 AM
Section line disappears from plan when section view is placed on same sheet
Thu, Sep 4, 2014 at 7:46:20 AM
Page generation time: 2.5019
