70 Users Online (69 Members):
Forums >> General Discussion >> Revit Project Management >> Fittings assigned to room outside the room area?
12 Posts No Rating |
Is is possible assigning a fitting, for example electrical fixture (light switch) to a room area that behind a wall? Mainly this is to do with scheduling and material takeoff.
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
You can assign a fitting whever you wish. Whatever Room it falls within- it will be associated with in schedules. Create use of Room Seperation lines and "Room Bounding" properties, will probably achieve what you after (which I'm not exactly sure of!) Regards, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
I think REVIT determines where something is from it's origin. I've had to work out problems where invisible lines place an object in the next rooms schedule. I've not had time to completely discover the rules but I've fixed my issues. If you go this route, you might want to create this as a seperate family so that it isn't confused with the correct one.
Room tag not showing in only one room. |
Fri, Oct 1, 2021 at 11:04:59 AM
Room Bounding - Room area changes, then changes back for no reason! |
Wed, Apr 28, 2010 at 6:22:40 PM
Room area calculation |
Sun, Nov 25, 2012 at 2:28:44 PM
changing the scale of my room and area tags with the scale of my area plan. |
Fri, Oct 22, 2010 at 10:38:38 AM
room area calculation |
Thu, Jan 15, 2009 at 5:51:20 AM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
