74 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Adding Battens to Wall
Sun, Nov 18, 2007 at 8:57:17 PM | Adding Battens to Wall
donna3d
Should I use a wall sweep to add vertical batten details to a wall? I am trying to create some craftsman-style detailing to the top of a gable wall. Thanks! -Donna
Mon, Nov 19, 2007 at 9:11:00 AM | Adding Battens to Wall
You could do it that way but the ends of each batton would be square and probably would not clean up with any diagonal trim.   I've found sweeps to be hard to work with in some instances.  A few are ok but you will have many.
An in place family that does all of your trim / battens would be easier.  Just do it all at once as one extrusion.
Mon, Nov 19, 2007 at 1:49:08 PM | Adding Battens to Wall
TomDorner
4.5 Stars: 25 Votes
I would look to the curtain wall tool and place a separate curtain wall in front of your exterior wall.  I would define the curtain wall to have mullions the size of your battens and replace all the panels with 'empty' panels.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Mon, Nov 19, 2007 at 3:33:19 PM | Adding Battens to Wall
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
The curtain wall might work for craftsman style, but maybe not for trimwork with pieces that are off the orthoganal grid in the middle of the system...or have they fixed that? I haven't checked lately, but I hope so, I really didn't enjoy building a storefront out of 13 little pieces.
Wall with horizontal and vertical battens
Thu, Apr 22, 2010 at 4:01:20 PM
Wall with battens
Sun, May 5, 2013 at 8:43:24 AM
Angled battens
Fri, Jun 13, 2008 at 4:22:34 PM
Wall with exterior vertical battens
Mon, Jun 12, 2006 at 10:23:53 PM
Creating gable battens.
Tue, Jan 13, 2004 at 9:12:54 AM
Page generation time: 2.1945
