84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Importing AutoCAD MEP 2008 files into Revit Architecture 2008
Fri, Nov 16, 2007 at 1:17:27 PM | Importing AutoCAD MEP 2008 files into Revit Architecture 2008
JDDeming
I have created my architectural model in revit.  Now I would like to import ductwork and HVAC equipment into my model.  All of the ductwork has been created already in AutoCAD MEP 2008, however, I am having trouble with transferring everything into Revit so I can view it in my model.  Once imported into Revit, I seem to lose all of the ductwork transitions and instances where a duct would change direction, for example.  Some of the ductwork runs lose shape for instance; a long duct that was 12" x 12" now shows up almost like a wall going all the way down 1 level, so it shows up as 12" x 120" or whatever.  Also, some duct runs lose their 3d properties all together and show up as flat plane objects.  I am totally confused as to why it looks perfect in ACAD MEP, but is so messed up after the transfer.  I have tried changing proxygraphics to 1 before exporting, saving as all different file types and no luck.  The only one that seems to retain all the correct information is a .dwf file, however, that file cannot be imported into Revit as far as I know.
Can anyone point me to a training guide for this sort of thing?
Has anyone successfully imported objects created in AutoCAD MEP 2008 into Revit Architecture 2008?  And if so please pass on any suggestions or tips.
Thanks.
Fri, Nov 16, 2007 at 1:27:47 PM | Importing AutoCAD MEP 2008 files into Revit Architecture 2008
JDDeming
I found this link about my problem above, only thing is it is for Revit Structural, not Architectural.  I am assuming it would still apply.  I am going to continue playing around with this, in the mean time, if anyone sees this feel free to add any tips.
 http://images.autodesk.com/adsk/files/effective_collaboration_using_revit_structure_and_autocad_mep.pdf
--New Revit MEP 2008 User--
Tue, Sep 25, 2007 at 1:06:09 PM
how to import revit 2008 data to autocad 2008????
Tue, Apr 8, 2008 at 10:12:03 PM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008
Tue, Nov 20, 2007 at 12:37:43 PM
Linking 3D Dwg files from AutoCAD Architecture to Revit MEP
Thu, Aug 26, 2010 at 7:48:24 AM
training files for 2008
Sat, Dec 24, 2022 at 4:48:32 PM
Page generation time: 3.0238
