60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stone work help
Thu, Nov 15, 2007 at 12:09:48 PM | Stone work help
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello,
 Ok I know a lot of us out there have worked on projects with stone veneer.  What is the best way to put hatch on our walls.  I am using the Carolina Ledgestone Model Pattern on my stone material.  But it is not pretty.  I don't like that hatch at all.  We've been using a hatch pattern that looks like ashlar (look at attached image).
The way I drew the image onthe right was use model lines and hand draft those lines to appear in both elevation and 3D.  But when we move a wall, those lines then float in space.  Is there anyway to make/find a hatch pattern that is similar to the ashlar and use it as a model hatch?  I don't care if it covers the entire wall.  I just care that it has the same rhythm to it.  Thanks
Lorne
Denver, CO
Revit Architecture
Thu, Nov 15, 2007 at 4:04:50 PM | Stone work help
ebtaylor
3 Stars: 2 Votes
Does 9.1 have split face tool?
Thu, Nov 15, 2007 at 4:31:56 PM | Stone work help
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Yes why do you ask?
Denver, CO
Revit Architecture
Thu, Nov 15, 2007 at 4:38:20 PM | Stone work help
ebtaylor
3 Stars: 2 Votes
1) use the split face to add your pattern to certain areas of your wall to give the effect you want ... or
2) create your own pattern to do what you want
Thu, Nov 15, 2007 at 5:10:45 PM | Stone work help
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is creating my own pattern what I already did?  My main concern isn't having it on the wall partially.  It's finding a stone hatch that actually looks good.  Or find an Ashlar stone hatch pattern.  Anybody know of any?
Denver, CO
Revit Architecture
Stone Walls, Stone Veneer, etc
Fri, Oct 6, 2006 at 8:21:58 AM
Wall Clading- Shaded stone/ Brick
Mon, Aug 24, 2009 at 7:05:03 PM
Stone Wall
Tue, Aug 20, 2013 at 3:55:33 PM
Stone walls
Sat, Jan 12, 2013 at 5:40:42 AM
Stone Pattern RAC V2009
Fri, Apr 25, 2008 at 10:30:15 AM
Page generation time: 0.6948
