47 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Hide the elevation circles from floor plan
![OktoberFire Avatar](user_avatar/44610.jpg)
64 Posts No Rating |
can these been hidden when i put my floor plans on a sheet? if i edit them on the Floor Plan it deletes my north etc elevation view
![3 Stars: 2 Votes](/images/stars_3.gif) |
If you are not putting the elevation view on a sheet, you can plot without showing unreferenced view tags. You will still see them in Revit, but they will not plot. If you dont want to see any elevation callouts, you can turn them off in Visibility/Graphics. If you are using 2008, you can select the tag, right click and select "hide element" to hide individual tags.
thank you, once i've hidden them how would i get them showing again ![Smile](/images/smiles/smile.gif)
The show hidden elements button at the bottom of the view window. It's the light bulb next to the scale, detail level etc. buttons. When you click it your hidden elements will show up and you can edit them without unhiding them, or you can unhide them so they will show up.
excellent! thanks for the help
Elevation Level Marker Associated To Wrong Floor Plan |
Wed, Feb 25, 2015 at 10:44:23 AM
Floor plan visibility: All equipment on the floor below are showing! |
Wed, Nov 4, 2015 at 7:32:48 AM
Hiding selected section/detail annotation floor plan and elevation |
Wed, Oct 2, 2013 at 10:28:28 AM
How can I hide a portion of something from floor plan view? |
Wed, Apr 18, 2012 at 4:22:59 AM
Revit's collor fill hides floor slab floor slab doesnt hide stairs anymore |
Thu, Feb 8, 2007 at 2:08:28 PM
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
